underdrive pulley question?
uhoh5.0
354
Montgomery, AL
Are there any concerns with using underdrive pullies in an auto equiped car? I thought I read something once cautioning against this, but I really don't see how that could be an issue? Also, I read somewhere that the newer GTs (2004) didn't benefit as much from pullies because they where already redesigned to allow maximum power with optimal cooling? I also have the mach 1000 sound system!
If you are considering getting underdrive pulleys for
your car get Steeda underdrive pulleys and have no
worries because they are non-piggyback.I have had
Steeda underdrive pulleys for four years now and I have
not had a single problem.
Anytime you make a modification to something you're obviously running the risk of having problems. You switch the alternator pulley, which opens you up to charging problems, switch the water pump pulley, which opens you up to cooling probs, etc.
However, I would venture to say people with an electric water pump are pushing around the same amount of water around as people with underdrives are.. and the alternator pulley you swap on is hardly any bigger in the Steeda kit.
I put them on mainly because it made my crank pulley look 20 times better than the stock rust colored piece of **** did. Haven't had any cooling probs, and I live in AZ with the A/C blasting constantly. No charging issues yet. I didn't notice anything performance wise.. maybe easier reving or something, but it's not like it'll smoke the tires from an 80 roll now or something.
i freekin love these posts..
it starts with underdrive pulleys..??
then its yeah just get steeda...!!
then killy says "dont bother they stink, dont waste your money"
then i say get them, they ad minimal power (just like everything else) and they are safe, and worht it..
then someone says "hey killy you dont install anything anways (except oil)
then someone says get them..
then the original post person says sounds goos
then killy says...hey wait i can get another post on here, and says "yeah just have it installed by a pro"
then someone says....did it myself...
ayadfaayafyayfyafyafyaya yafya
to heck with it..
did that cover everything..??
to heck with it..
Yeah, pretty much... :rlaugh: :flag:
Kilgore Trout said:
Don't waste your money and risk your engine by installing pullies that will do nothing for power anyways :notnice:
I only got about 4.5HP with mine and I would wholly agree with you: I wouldn't spend the money on this mod again nor would i recommend it to others. Leave the pulleys that came on the car and put the money toward other go-fast stuff.
to heck with it..
thats the routine but i'll do a 2 for 1 post if you have any doubts have a professional do it.......otherwise its an easy install i did it on my car took about 30-45 min with a few breaks in between
They have been the cause of failed oil pumo gears and damaged engines. They aren't worth it unless you go with ATI and a good balancer.
People don't see the damage they have caused, yet the main engine builders have.
They can cause damage even if installed correctly, if their design is deficient. That's the problem with them.
The crank pulley has a damper on it, a ring of iron adhered to the body with a stiff elastomer. That assembly is specifically tuned -- mass, diameter, durometer of the elastomer etc -- by Ford to dampen torsional vibrations of the crankshaft that show up at the snout of the crankshaft.
There are eight power pulses being fed into the crank every 720 degrees of revolution and because of the length of the crank, it's going to bend ever so slightly with each cylinder's power stroke. When you have eight cylinders feeding in power pulses continuously, there may be points in the rev band when the power pulses are being fed into the crank that match the natural frequency of the crankshaft (or one of its harmonics). When this happens, you can get constructive interference and a rapid increase in the amplitude of the overall vibration. Think of the Tacoma Narrows bridge to see the effects of constructive interference.
The damper is there to alter the vibration characteristics of the system by acting to dampen them. When you change the pulley to a really small diameter damper with little mass, you've taken away the only mechanism to dampen crank vibrations which Ford went to considerable engineering effort to design.
Because the oil pump is driven directly off the crankshaft (right behind the damper, timing wheel and crank sprockets), and (in part) because the OEM oil pump gears are powdered metal, it is possible for these vibrations to pound the pump gears until they shatter, usually taking the entire engine with them.
Piggybacks get a bad rep but at least they preserve the factory damper mass and design...
easy does it......
ok bought them the day i bought my 04, no problems, and runs great.
now how do you counter that my car does not run great......????
:rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
For starters read the post above you.
Now Modular engines builders like Al Papito(Boss330Racing) who is known to be one of the best if not the best engine builder(built Bob Cosby's 2004 World record holder NMRA F/S car) has had 9 engine fail including his own 500+ rwhp 5.4 DOHC due to an underdrive pulley. He has built some of the fastest all motor Modular motors and has set records. He has also pioneered new designed like carbed intakes for the modular motor as well. He has been building and racing cars for over 30 years now and has been in the Mustang magazines and known to build some of the fastest Modular Mustangs.In addition John Mihovetz who has the fastest modular motor car, Ed Olin, and some other well known guys have seen them.
Boss330 said:
Here's a pic of the crankshaft that came out of Bob Cosby's Cobra.
This engine had 12-15 dyno runs, 200 street miles and 32 1/4 miles passes.
The engine was torn down under an official NMRA protest in Kansas city after Bob reset the National record five times in one weekend and winning the event.
This engine had a small dia underdrive damper. The damage to the flats that drive the pump are obvious. Also obvious are the witness marks on the opposite side of the flats. (As EDO pointed out in one of the many oil pump threads) The crankshaft drives the pump, The pump does not drive the crank.
So.. There should be marks on the crank in only one direction ( Where all the damage is in the picture) Why are there marks on the opposite side?
The answer is the front of the crank is sizzling with harmonic vibration, Just like a giant tuning fork.
This vibration is passed on the the pump,Chains,sprockets,cams,valvetrain.
after the pump the next thing that fails are the cam sprocket bolts. Myself, Carlos Nazerino, and Joe Lynch come to mind. I warned Joe after i blew a very expensive engine. Joe's ran a year or so and was killed when a sprocket bolt failed.
This pic shows the beating the crank took. The only thing that saved this engine was the billet oil pump gears. Bob's engine was the last to leave my shop with a u/d damper, that was 2004.
Here is a great post by Ed Olin who was the engine designer of the 5.4 00Cobra R and his commented on vibrations by our dampners due to Underdrive pulleys
EDO said:
This seems as good a place as any to bring up my observations on this subject, so here goes a very wordy commentary.
Doug, take a look at your crankshaft where the flat surfaces are machined that drive the oil pump. Since the crankshaft should always turn the oil pump (instead of the oil pump turning the crank), there should only be significant marks on two ends of the crankshaft flat surfaces, not on all four. If there are four distinct marks, then I suspect a crankshaft torsional vibration is a possible cause of the oil pump to shatter, as the pump should never turn the crank so you should not see real significant marks on any more than two spots on the crank flats. My wording may be poor, but if you look at the parts and think about it, then it should make sense.
What can cause the torsional vibration (or twisting)? Well, all crankshafts in engines have some amount of this twisting due to the combustion pressure pushing the pistons down and that causes a twisting motion in the crank. Since there are distinct intervals of this going on depending on the number of cylinders, the crankshaft rpm is continuously increasing and decreasing at different rates at different points along the length of the crankshaft itself. This is very minor, so you don't notice it, but the crankshaft feels it and over time it can break or break things that are attached to it. The flywheel and clutch (or torque converter in an automatic) dampens out this twisting at the rear of the crankshaft, but the front is just flopping around, so a torsional vibration damper is installed on the front to control it.
The production crank damper is tuned to reduce this vibration at specific rpms where it is worst and is then deemed appropriate for the production engine. Things that affect the ability of the production crank damper to do its job are:
- changing the crankshaft material (like from a GT cast crank to Cobra forged steel or aftermarket billet),
- changing the stroke (like using a 4.6L crank damper on a 5.4L crank or the opposite),
- running to a higher rpm than production fuel shut-off (since the production crank damper would not have been designed for it and there may be bad vibrations up there that are uncontrolled),
- dramatically increasing the input loads from combustion (each impulse into the crankshaft is much greater, therefore creating more twisting).
In your particular case, you certainly did the last one by using nitrous. But, I'm not aware of people having problems such as yours from nitrous use alone, so this effect may be minor.
However, there are a couple other things that can have a major effect on crank torsional vibrations in general and these are:
- aftermarket superchargers
- aftermarket crankshaft dampers.
You are not using an aftermarket supercharger, but I suspect you are using an aftermarket damper (instead of the "piggyback" style, which can still allow use of the production damper). I really don't know if aftermarket crankshaft dampers are properly tuned, but from what I've seen over the past several years when someone breaks a production oil pump, that does seem to be a common link, so I suspect they may not be tuned for how you are using it.
The other major player is aftermarket superchargers, particularly centrifugal types. I am not aware of any problems related to this with any kit that can be purchased and installed properly, so don't take this as a condemnation of those kits at all. From personal experience, those kits work great. But, when a person gets greedy for more power (face it, we all do, that's why we modify our Mustangs) and doesn't do all of the upgrades properly, problems can result. For example, I broke 3 production oil pumps in my '96 Mustang GT several years ago. The standard Vortech kit was great. Running a smaller pulley for more boost was even better. Swapping to a T-trim was fantastic. But then the oil pumps started shattering. I was lucky enough to see when they would break. It was when I slammed the throttle shut at high rpm at the end of a ¼ mile pass. All 3 broke under the same condition, and with the configuration the car was in at the time, it would only take about 20 passes for it to happen. After lots of looking at the hardware each time and discussions with people having more knowledge, it appeared to be fairly obvious that it was a crankshaft torsional problem. But why was it happening with the T-trim and not the standard S-trim blower? Well, the thought was that the supercharger bypass was not large enough (I was foolishly still using the little plastic bypass from the standard Vortech kit instead of upgrading to the bigger bypass) and the compressor was going into surge. This was being fed back through the supercharger belt and down to the crank, producing rather violent torsional vibes. Unfortunately, as much as I was having fun with breaking parts and learning, I decided to do the PI headswap thing and run naturally aspirated at that point, so I never went back to completely prove/disprove the theory.
But based on personal experience, some logic and seeing what other people have written about their oil pumps breaking, it almost always seems to be caused by one of the reasons listed (aftermarket crank damper, running higher rpm than stock fuel shut-off with the production crank damper, or using a centrifugal supercharger and a bypass that is too small).
The aftermarket billet oil pump gears are stronger than the production pieces, but that is why they don't typically break, not because they address the basic reason for the breakage to begin with. I suspect the production pumps should be okay for anyone who stays with minor mods or even major mods if the above concerns are addressed.
By the way, I suspect Al's (Boss 330) pump breakage was likely due to running the engine way above the rpm range the Navigator crank damper was designed for. Or if he was running a 4.6L Cobra damper then it was not tuned for the 5.4L crank torsional characteristics. However, I applaud him greatly for what he's done pioneering the 5.4L 4V performance!
These are just my thoughts, but it may give people some insight as to what is going on (or a good nap if they fell asleep reading it). - EDO
Now let's see your credentials and how Mnay modularmotors you build and records you broke and I might, just might consider you someone who should be promoting the opposite of what the greats say. This is why they rarely post anymore.
easy does it......
Your one anectdotal experience means much less than the experiences of engine builders who have seen many many engines and have a larger statistical sample to base their assesment on.
mine are in my 2004 stang...no problems.......loooooooove them.......highley advise anyone to purchase them.....and enjoy..
thanks
as far as my credentials, i own a mustang, installed the pulleys on my mustang, and they are grrrrrreat on my mustang. hows that.
but if thats not good enough.......i am also very tall...:D
