Using maf with megasquirt pnp
options port pin #19 or pin #10 both can be used.
knock input is ADC2 - AD7
Baro is ADC1- AD6
either will work but if you are using the external map pin be aware you will have to jumper it over inside the case.
The bolow picture below is from a how to I helped with for one of the digital dashes offered by dd-efi but instead of oil pressure you can use it to bring the MAF in. the jumper used is a common pin jumper used in arduino projects
Reactions: 1 user
