Grn92LX said:Your launch looked good. Your 2nd to 3rd and 3rd to 4th gear shift could use some work (faster) What gears do you have? I'll assume at leasta 3.73. After you roll through the water box, do a stand still second gear burn out til you se smoke then let it out.
Have you ever tuned the car? The mph just seems way low even for a mild 331.
but i understand why you are shifting that way. Killercanary said:I can not view it because it is a DIVX format.
nmcgrawj said:whoaaaa. Yea those shifts are probably taking a couple tenths off atleast!but i understand why you are shifting that way.
Is that the stock rear end axle wise? Those tires probably want to be a little warmer. Probably gonna help out the 60ft time once u do.
slvrbullit302 said:Paul, you can go to divx.com and get the player for free.
