Buddy has a vortech v2-SQ on his 94 5.0 aode. He has GT-40 iron heads, Comp cams camshaft (XE270) and a trick-flow street intake. Bottom end is all stock.
He is wondering where to set the MSD boost timing master. Right now it's working OK at 1.25 deg/lb boost, beginning at 1 lb. but he is pretty sure it's capable of more power cuz it's a bit sluggish at the top end.
At 7 lbs, that leaves puts him at a max retard of 7.5 degrees total. base timing is stock 10 deg BTC. Where do you guys run your intial timing and what are your BTM settings when running a supercharger?
Thanks!
Thanks!
