vortech v1 T trim
it wont work.... send it to me ASAP. :D
You'll need 42lb injectors, new maf, 255 walboro fuel pump, I don't believe the ignition system is necessary since you ar mostly stock but you will need to re-gap your plugs and reduce timing. Also your going to need a chip/tweecer/pms etc to tune it.
nice pickup!
thanks ,i think i made out pretty good for 750 bucks. its just the blower, brackets, and the pipe going from the throttle body to the blower.
anything i should look at to double check it?
i made sure it wasn't locked up there, but im not sure what else to check for.
hm. i'll have to look into that site.
theres a 94-95 replacement throttlebody that says uses stock cables and such, would i still need the elbow to hook that up to my intake or can i just order that instead of do a fox conversion?
Here's a spreadsheet I put together with everything you need to piece together an S-trim kit. I made it into a .pdf to be easier to read.
http://members.aol.com/fiveliterstang95/public/StangNet/supercharger.pdf
Obviously you don't need the bracket, but that should cover everything else for the supercharger kit, as far as I know. You'll still need supporting mods, and with the T-trim, you'll probably want to add the Vortech T-Rex pump, as well.
so i don't need anything like the boost retard box?
and would 89-93 brackets work?
i can basically just pick up whats on that list and it will hook up, aside from bigger injectors, a bigger fuel pump, and a tune?
just picked one up at the swap meet for a good price, what do i need to put this thing on?
what size injectors, what size fuel pump, do i need to upgrade my ignition system, any kinda master install kit?
What kind of price did they give you, and what came with the V1 as you bought it?
RC
