weird clutch install problem
  • Thread starter Thread starter bnichols04
  • Start date Start date Sep 13, 2010
bnichols04
45
  • Sep 13, 2010
i am installing a t-5 in my 5.0 mustang and i am going to install the new clutch and i noticed that the outside edge of the pressure plate is about 3/8" away from touching the flywheel. is this normal? i can run in the bolts to make it contact the flywheel but they feel too tight and actually broke one off. i got the broken bolt out but something isn't right. here are some pics to show you what i am talking about.
http://s445.photobucket.com/albums/qq171/bnichols04/?action=view&current=100_5573.jpg
http://s445.photobucket.com/albums/qq171/bnichols04/?action=view&current=100_5574.jpg
http://s445.photobucket.com/albums/qq171/bnichols04/?action=view&current=100_5568.jpg
Rick 91GT
Mustang Master
95
99
PA
Sep 13, 2010
  • Sep 13, 2010
The photos are not showing up...
Is the clutch located on the dowel pins properly? Are you tightening the PP down in a crossing pattern? The PP may not go all the way down again the flywheel, but if your seeing 3/8" and breaking bolts something is wrong. Did the bolt brake before you reached proper tq?
bnichols04
45
  • Sep 13, 2010
ok i fixed the links. no the bolt broke before i got it torqued
W
wv109323
100
Lenore ,WV
Sep 13, 2010
  • Sep 13, 2010
Clutch
It looks to me like bolts are not fully threaded and the shank of the bolt is bottoming out before the pressure plate is tight against the flywheel. Where did the bolts come from?
bnichols04
45
  • Sep 13, 2010
the bolts came with the clutch and flywheel. they are made by zoom
1993SSP
1,194
Ky
Sep 13, 2010
  • Sep 13, 2010
You do have the clutch disc turned the proper way ?? It's been awhile since I had one apart, not sure if that could be your problem or not, if not that something is def up with the pressure plate I would think, I'd give zoom a call if possible
HISSIN50
34
129
Sep 14, 2010
  • Sep 14, 2010
Did you try running any of the bolts in before installing the PP?
Rick 91GT
Mustang Master
95
99
PA
Sep 14, 2010
  • Sep 14, 2010
The bolts for sure have too high of a shoulder from what it looks like... I know I had a customer bring me some Mr.Gasket bolts one time and they were close but didn't work. Try your stock bolts, they are fine to re-use....
If I remember correctly the stock flywheel doesn't have through holes for the PP like the aftermarket pieces are the bolts bottoming out?
bnichols04
45
  • Sep 14, 2010
my flywheel is an aftermarket one that has holes that are threaded all the way through the other side. i'll try some different bolts then hopefully that will work
Mustang II V6 conversion to V8 HO and T5 problems and solutions
  • greenflash79
  • Jul 6, 2025
  • 2 3
2K
1974 - 1978 Mustang II Talk & Tech Saturday at 3:52 PM
greenflash79
NEED SOME SPEC CLUTCH DIMENSIONS
  • PonyGTrider
  • Jun 2, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2024
PonyGTrider
For Sale 1995 Mustang GT Convertible FOR SALE
  • #16Stang
  • Jun 21, 2024
SN95 Mustangs For Sale (1994-04) Jun 21, 2024
#16Stang
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
