Weird Problems
  • Thread starter Thread starter 92GreenGT
  • Start date Start date Jul 31, 2005
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Jul 31, 2005
  • Jul 31, 2005
Cranked my car up after getting the engine back in and all that jibber jabber and filled it full of fluids. Started it up and came up with three weird problems, my AutoMeter Oil Pressure gauge doesnt work and my AutoMeter water temp gauge goes straight to 210 after the car is cranked. I have a feeling its something to do about a ground wire, becuase its not common for two autometers to die at the same time. Next problem is when I start the car, the "Check Oil" light comes on...first time I started it this light never appeared and now it just popped up. What do you think would make that light come on?
HISSIN50
34
129
Aug 1, 2005
  • Aug 1, 2005
is there enough oil in the motor? On a fresh motor, it can take drink some sticking it in dry places.
I would just trace your AM gauges' sender wires to make sure they are not pinched (I assume they are electric gauges). Generally the more resistance in the wire, the higher it reads.
You can toss a temporary ground on the senders to ensure they are properly grounded, but I doubt that is it.
All the motor grounds are in place and all wiring harnesses connected?
No great advice bud. Good luck.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Aug 1, 2005
  • Aug 1, 2005
Maybe I should have put oil in the engine? Yeah the engine is full of oil(I filled it up to the top of the valve covers...thats right isnt it? ) enough playing, but seriously its filled with oil.
All harnesses are connected and everything is grounded. I dont understand about the gauges though, the only wires I have had off both are the two sender wires from each of their senders.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
