went to the track
rayvinton
59
went to the track last night and best run i could pull in 80 degree + 80% humidity was a 13.62 with a 1.88 60', does this sound about what i should be getting or faster? I have UDP,CAI,70mm TB, bassani exhaust, 75mm upper plenum, aluminum driveshaft, 3.55's with slicks.
I would step up the gear to a 4.10 if you want to make more passes. 3.73 at least. I ran 14.25@99 with the 2V set up in my notch. CAI, BBK H pipe, MAC cat-back and 3.73's and a 2.2 60ft time.
No the motor is a 2001 GT 2V. So it is Performance Improved...(PI) It wouldn't hook to save it's life in 1st, and even WORSE in 2nd. 2nd was scary....damn F1's suck.
