went to the track
Wow, you should of ran a high 13 even without traction.
The track i go to is HORRIBLE and elevated around 1500, and totally unprepped every time (You chirp third long enough to have the backend shake a little) and my car ran a 14.2 with H pipe weld muffs, and KN and plenum with stock throttle body.
A fox weighs what, a thousand pounds less? and it 4:10s, ohhh man- i bet that car pulled a little semi wheelie?
Vids of the r un!!
I have a 3.73, not a 4.10. The notch weights maybe 400lbs less, not 1000lbs less. Our track is unprepped as well. I didn't build it for that reason anyways, I built it just for fun. I only went to the track to see what it would do, because I had nothing to do that day, I was bored.
They were anywhere from 2900-3100 depending on factory options, aftermarket modifications, wheel/tire combo etc.....
Mine will be heavier due to the fact I have 17X9's 285 tires, the complete 2001 GT ABS unit, hydroboost, interior, etc.... Maybe about 3100-3200lbs.
