what are these TWO things and can i delete them? *pics*
ShortThrow50
923
Pa
93 lx 5.0
the first pic is some sort of little bar that connected to the upper and lower intake postioned as shown. This came off the stock upper and lower. I cant see what the purpose was. I have trick flow upper and lower now and wish not to install it if i dont need to. Anybody know for sure?
Next, i bought a brand new frpp stcok iron flywheel (pictured below). I had to, of course, transfer the old dowel pins over to the new one. I noticed in the old flywheel it had some sort of peice (shown below in my hand) that was mounted flush in about the same hole picture where iam holding it in the old flywheel. If this is some sort of counterweight, what next? I dont want to put it in the same spot and hope the flywheel doesnt get thrown off. I never heard of having to do anything to a new flywheel so iam hoping you guys say to just discard it and mount the flywheel in as is.
i swapped over every dowel, one at a time. i beleive there was three. That last thing im holding does not bear nearly the same shape as the dowels so that cant be one. I stopped to talk to a buddy of mine who is a mechanic and he tells me the frpp flywheels come balanced and he wouldnt swap that over. I just figured maybe you stangers could give better insite.
mmm, i thought it used 4 or 5 dowls, that little thing in your hand resembles a dowl. the FRPP flywheel you got didnt come with new dowls? maybe when sombody put that old flywheel in they lost or messed up the dowl, and just put that in there so it wouldnt make if off balance.
I have one installed on my car except "0" balance so there were no weights on mine. My Centerforce had holes drilled in it for the 50oz imbalance.
It seems as though someone may have stuck that in there down the line and it's not supposed to be but I would not put my money on it.
Call Ford's tech line and see what they say about it. You're better off since no one has really seen the part your describing being used for balancing.
