Well, with my tune and an Extender, I went 13.20's at 105...
With my $400 custom FordChip, I went 13.20's at 105, with a one-time perfect condition
[email protected] I gained nothing but headaches...lol...
To my knowledge only the Cobras had any kind of speed limiters...The GT's do have a "tip-in retard" that retards timing every time you apply the gas pedal, like if you let off the gas to shift, for example. This was done by Ford to help lower the number of warranty claims on the five speed cars. An Extender, a chip, or most any of the "tuners" will eliminate that. I have my PMS setup to make the car run in "StandAlone" at 2000 rpm's and 50% TPS voltage. In other words, if I'm over 2000 rpm's and the gas pedal is halfway down or more, the PMS is controlling everything as far as how the car is running. It is not running on any of the Ford factory ecm parameters.
As for your trap speeds, taking a quick peek at your signature, it looks like the overall combo simply isn't matched as well as it could be...Heads and Intake are more for higher rpm because they breathe well, but 355's cannot posibly let it stay in the sweet spot like a set of 410's would. Naturally aspirated, you'll never trap what it should with 355 gears. 410's would really pick it up, or even 373's is a happy medium. I had 410's, but swapped back to 373's so I wouldn't run out of motor when spraying it. I shift at 5800-6000 and go through the traps at 5500-5600rpm's N/A...6000+ with the nitrous.
I have stock Edelbrock 60379 heads, an AFM B-21 cam, and an Extrude honed Cobra intake and the day I dyno-tuned the car, I went 12.88@107 N/A, 11.92@116 on a 100 shot of nitrous. My car is far from setup for the strip. It's lowered, has big rims and tires, swaybars in place, nothing removed for weight savings, and it's a fully optioned leather interiored GT. Personally, if I had your present combo, I'd swap to a Street Heat upper, a 65mm TB, and a gear swap to at least 373's, maybe 390's, or for a maximum gain, 410's...Your car would run much better IMO...even without a "tune"...
