Get a mechanical FMS fuel pump and timing cover and eccentric to run it and NEVER have to think about fuel pressure ever again. Ever. Perfect pressure every time year after year. Just my .02 on that issue.
750 cfm is way way way too big. 650 is better, I agree. Maybe even 600 cfm for throttle response if it is not a high revver. 650 if it is. Plus the dp had the potential to bog when throttled too suddenly. Thats why I dont like mechanical secondary carbs. They always seem to run pig rich no matter how well you tune them. A 650 vacuum carb might even give you more throttle response and no 3k lean bog since the vacuum secondaries are inherently load sensing and only pumps as much as the car needs. The dp principle of blasting fuel in there is not always optimal since super rich is detrimental to power production as is super lean.
Point in case, my 40p headed 302 works absoilutely best with a 570 vacuum secondary and not the 670 vacuum secondary or even the 600 dp. You need velocity to suck gas from the boosters and that 750 is killing all your air velocity guaranteed.
