what do I need to get this to pass smog?
fuzymealchosen1
41
its got long tube headers. an h pipe that has no cats at all, and flow master mufflers.
im in southern california and i need to get this legal to pass smog :bs:, and im just wondering what i would need to do to make this pass smog.
thanks,
im from norcal and up here my 92 passed smug with the stock h-pipe and 2 chamber flows with dumps:) so my guess is yeah you need to have at least 2 cats to pass the sniffer and visual. make sure your timing is set to 10 degrees and drive your car for a while to warm up the cats, also you can use additives in your gas tank. andyou can avoid complications by having a pre-test done so they dont send the actual smog test results to dmv in case it dont pass and good luck trying to pass the visual with longtubes unless the yare carb legal they prob arent tho you can try to find a place that doesnt really care about the visual and only cares about the sniffer test witch you still need cats to pass.
ok thanks, um im new. what is "with dumps" sorry
welcome to the site! is this your first stang? its ok "dumps" or "turn downs" are typically on race cars that cannot use tailpipes or dont have enough clearance for them, they are short pipes welded on after the mufflers that curve down and are pointed directly to the ground about 7-8 or so inches in length i dont think the dumps were smog legal but they passed so i guess they are. i dont think long tubes are tho. try to do a google search for long tubes and ca smog
How to pass emissions testing:
High NO - high combustion temps - retard timing, check EGR for operation.
High CO – Rich condition - fuel pressure too high, check O2 sensors, replace air filter, Clean MAF element.
High HC – Lean misfire, vacuum leak, common misfire due to worn or weak ignition system components. On rare occasions, an overly rich mixture may be the cause. Do the ethanol/E85 fill up as suggested.
High CO & HC - Cat converters, smog pump, and smog pump controls.
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats. The smog tech will do a visual check to make sure that all the original equipment is present and connected up.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
thanks! its my 1st car :D
ohh ok, right now i dont even have tailpipes. :rolleyes:
i tried doing a search, somebody told me that the longtube headers wouldnt pass the visual cuz it needed the stock h pipe.
i was thinking of just getting all stock stuff, and getting it smogged then putting it back, but i kinda dont want to deal with the egr. and that weird smog ball thing.
thanks other guy im gunna read that in a sec.
if u get the stock headers then yeah you probably will pass. you just need to have all your smog stuff hooked up mainly the thermactor pipe that goes to the h-pipe and egr is important for it to pass visual. what smog ball thing are you talking about? where is it mounted?
