* Advertised duration: 280 intake/280 exhaust
* Duration at .050 in. cam lift: 230 intake/230 exhaust
* Gross valve lift: .530 in. intake/.530 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 2,000 to 6,000
* Mild rough idle
The other cam i bought I was told was kind of small so I seen this one at Summit. I might return the other one. I have a 72' 351c, edelbrock performer intake, 600cfm edelbrock carb, im rebuilding it soon with flat top pistons, should net me about 9.1 to 1 compression, Fmx tranny with stock stall converter, I might go to a bigger stall converter eventually but low on cash so stock has to stay for now. Also planning on 3.70 gears in the future but stock 2.75? will have to stay for now. Guy tells me he thinks it has 3.73 but the tag says 2.75 unless it was changed in the past. Do I want a cam with more low end power for a 73' mach 1? Also will new stock springs on 2bbl heads handle a cam like this or will I need aftermarket springs?
Thanks,
Jim
* Mild rough idle
Thanks,
Jim
