Head gaskets,intake gaskets,timing chain cover gaskets,timing chain cover dowls,oil pan gasket w/ front seal,new distributor o-ring,new timing chain (really should),RTV clear silcone sealant,contact seament (for holding the gaskets in place),new timing chain cover-to-hamonic balance (front main?) seal,you'll need a balancer puller/installer,Lock-Tite blue,water pump gasket,valve cover gaskets,headers gaskets,if a new distributor gear/distributor make sure you use a moly lube (cam lube) and grease it up,new oil (important to not use synthetic oil to break in the new cam,lifters,gears),you can reuse the oil filter now for the break in,then you'll need another filter and oil change (you can us synthetic now),and of course all the scrapers,and cleaners.
I just went through it (and still am,lol).
