- Lift: .512"/.512"
- Duration: 281°/281°
- Lobe Separation Angle: 110°
- RPM Range: 2000-5500
I cant see where this cam is going to have street manners .... The cam is too radical for what your looking for just because max lift is small means nothing its even in the description of the cam- "Magnum camshafts are very aggressive and specifically designed for the street enthusiast looking for more power with that Pro Street sound. Intended for performance oriented vehicles that will see little street use. The idle characteristics of your engine will change due to the increased duration and overlap of the Comp Cams Magnum Cam Series. The hydraulic roller cams do dramatically decrease friction, as well as lifter wear. As far as power, the roller profile allows the design of more lift, and a greater area under the curve giving much better top end power without sacrificing bottom end. You will notice a racey idle with the 280-grind while the 292 and 305-grinds will produce a rough or ''rumbly'' idle. Stock components are incompatible. Changes are needed in rear end gear ratios, headers and the torque converter. Magnum Cams will affect your power accessories to a certain extent. The 280 and 292-grinds are the biggest cams that should be used with power assisted brakes, air conditioning, etc. You should remember that the bigger the engine is, the less the cam will affect the vacuum which affects your power accessories. The smaller your engine is, the more the Magnum Camshaft will affect your power accessories. Most late model vehicles have a vacuum canister. If your vehicle does not have a vacuum canister, it may be necessary to add one."
