what gear w these cam specs?
  • Thread starter Thread starter 90lxwhite
  • Start date Start date Jan 14, 2013
  • 3
First Prev 3 of 3
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Jan 28, 2013
#41
  • Jan 28, 2013
  • #41
Rick 91GT said:
That cam is not radical but wouldn't be my first choice with that set-up, seems like there are some other possible issues. I would have went with a wider LSA for a broader power range, and with no gear in the car it will be a little last down low IMO.
What is the complete combo? I see mentions of a carb but it was tuned SCT chip so I assume its EFI?
yeah it's efi, however the cam is not for efi cars, builders dumb mistake... Had to take for tune and change firing order etc.
gearheadboy
1,425
177
84
52
Greencastle Pa
Jan 29, 2013
#42
  • Jan 29, 2013
  • #42
Ok so that is a decent shaft. Here is a dumb question. So it is a roller. YES. From what I read it is designed to FIT in a 5.0 82-01 that was equipped with a roller from factory. OK. But I don't think it is for an H.O. firing order which means you have to change to non H.O. firing order, which you did if I read correctly. And you changed the injection wiring to H.O. as well? It may run smoothly if you did both of those things however the thing will never work good because the intake is not set up to work optimal with a standard firing order. I'm still thinking...
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 30, 2013
#43
  • Jan 30, 2013
  • #43
Yeah I believe when it was taken to get tune they electronically changed the fuel injection order. It's not running as rough as you fellas are thinking, it's just not smooth like it was when it was new and stock.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 30, 2013
#44
  • Jan 30, 2013
  • #44
tmoss lower is on the way we'll see what we get
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 30, 2013
#45
  • Jan 30, 2013
  • #45
I would have changed the cam so you had a H.O. firing order rather then do the tuning. The H.O. firing order makes more HP then the sbf firing order. That was a mistake by the builder.
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 30, 2013
#46
  • Jan 30, 2013
  • #46
The HO firing order also works with your cars computer to get the best power and driveability.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 30, 2013
#47
  • Jan 30, 2013
  • #47
day late and dollar short at this point in time..
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 30, 2013
#48
  • Jan 30, 2013
  • #48
What would you guess would be the power gain by switching to an ho cam? 5 or so and another $500 trip to the tuner?
88LX5.Oh
1,442
205
94
Arkansas
Jan 30, 2013
#49
  • Jan 30, 2013
  • #49
Your car is no longer stock so you can not compare it to a stock vehicle. You have aftermarket components and they are going to act differently than the factory components.
You complain about a low RPM buck, that's because the car isn't making any power at 1100 RPM, it needs to be spinning it higher than that so it won't be lugging around everywhere. This would be just like putting a larger cam in and not getting a higher stall torque converter (EDIT: if it were an auto). If you were to run a stock stall but your power comes in at 2500 RPM, you're sure to get some bucking. You need to ride your clutch out a little bit more to get into the power so you won't be bogging your motor down.
Will you notice a difference between 3.55 or 3.73's? You won't hardly notice a thing other than your speedo reading differently and a little bit lower RPM at cruising speeds. Going to a numerically lower gear ratio ("Higher" gears) is only going to make the problem worse.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 30, 2013
#50
  • Jan 30, 2013
  • #50
You complain about a low RPM buck, that's because the car isn't making any power at 1100 RPM, it needs to be spinning it higher than that so it won't be lugging around everywhere. This would be just like putting a larger cam in and not getting a higher stall torque converter. If you were to run a stock stall but your power comes in at 2500 RPM, you're sure to get some bucking. You need to ride your clutch out a little bit more to get into the power so you won't be bogging your motor down.
how much lower cruising rpm would you guess like 200 rpm less or so at 70 or more?
88LX5.Oh
1,442
205
94
Arkansas
Jan 30, 2013
#51
  • Jan 30, 2013
  • #51
Yeah I'd probably say just a few hundred RPM, it definitely wouldn't be very drastic at all.
Let me ask you this, what is your typical driving conditions?
Are you in town doing a lot of stop and go driving or are you going to be on the highway a lot?
If you're gonna be in town a LOT, don't fear the gear! But for highway, 3.27 would probably be excellent and would have a much more noticeable effect vs going with 3.55's, but that would only cause the low RPM buck to be even worse. Or you could really play with the clutch pedal and spin it up to a little bit higher RPM to overcome the buck.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 31, 2013
#52
  • Jan 31, 2013
  • #52
yeah
man its a mixture of both I guess, but mostly around town now since its no longer a daily driver. I think I'm gonna ride it out w/ the 3.73's awhile
castine917
126
Wyoming, Mi.
Jan 31, 2013
#53
  • Jan 31, 2013
  • #53
Going with a different cam and retune will likely benefit you better than gear change to start. I know it'll cost more but, remember that I've gone through exact same thing with the wrong firing order. I've also learned that some times gear is great and others not. 97 f150 5.4 a.o.d. had 4.56 and was perfect. 67 camaro 355 powerglide had 3.73 and 78 mustang 306 c4 had 4.10, I wanted 3.27-3.55 for those. F150 was best highway cruiser of all three. Tire height, trans gear, engine, vehicle use, and driver preference are all factors.
castine917
126
Wyoming, Mi.
Jan 31, 2013
#54
  • Jan 31, 2013
  • #54
Vehicle weight also is a factor.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 31, 2013
#55
  • Jan 31, 2013
  • #55
Which cam would you go with?
castine917
126
Wyoming, Mi.
Jan 31, 2013
#56
  • Jan 31, 2013
  • #56
Ed Curtis
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 31, 2013
#57
  • Jan 31, 2013
  • #57
castine917 said:
Ed Curtis
I was betting the farm that you or someone else was going to reply, "stock cam." I think that crappy cam is the only thing getting me 209 rwhp. I mean just has fresh e7's, 3 angle valve job, and beehive springs and that cam, lower intake sent for porting, and flat top pistons. W out the cam I'd be stock pretty much and maybe 184 rwhp $5000 + later...
castine917
126
Wyoming, Mi.
Jan 31, 2013
#58
  • Jan 31, 2013
  • #58
What compression with the flat tops?
baddbradd
14
Sylvan Springs, Al
Jan 31, 2013
#59
  • Jan 31, 2013
  • #59
what maf and t.b. is it? I know its got to be aggravating inheriting someone else mistake. Same situation i was in...
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Feb 1, 2013
#60
  • Feb 1, 2013
  • #60
I believe it's only like 9.5:1
stock maf and tb, and wasn't exactly an inherited problem. Took it to the builder, said make it fast, and this was end result. Sore subject
  • 3
First Prev 3 of 3
K
Electrical charging issue
  • knucklehead11
  • Jul 15, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 16, 2024
Mcmahst
The Death of a Cobra II
  • 76_Cobraii_mustang
  • Oct 2, 2023
3K
1974 - 1978 Mustang II Talk & Tech Oct 3, 2023
2Blue2
Y
400HP 2V N/A....Going back to my roots....
  • Yel2002GTAuto
  • Sep 26, 2022
  • SN95 4.6L Mustang Tech
  • 6 7 8
28K
SN95 4.6L Mustang Tech Mar 11, 2025
Bullitt347
Planned Cross Country Run - 65 Fastback
  • Smokinstang65
  • Aug 17, 2021
4K
1965 - 1973 Classic Mustangs -General/Talk- Feb 27, 2022
Baron von K 289
Progress Thread 2001 Bullitt #265 - Build Thread (LOTS OF PICS)
  • MineralMan
  • Oct 21, 2019
  • 2 3
14K
1996 - 2004 SN95 Mustang -General/Talk- Feb 7, 2026
gkomo
