what injectors should i go with for my 331???
juiced_94gt
1,143
Southern California
Well two of my 24lb injectors took a dump i tested the harness and its two bad injectors causing a huge misfire well it's a 331 with AFR 185's a track heat manifold, TFS stage 2 cam, 80mm LMAF and will eventually get a at least a 75 shot of spray...it's my daily driver so do bigger injectors equal more gas?? should i stick with 24's for a 75 shot?? are 30' or 36's a better choice?? I will go to steve at powertrin on monday to get my chip re-flashed for whatever i need.
i dont think 24ers were adequate for what ur running now..and if u throw nitrous in the mix its going to be problems..i would say 36#ers..
If you are getting a tune.... and you have the LMAF. Why not go with 42s and be done with it? That's what I'm running. Don has been able to tune it first a little lean, then a little rich. Next tune should be on the money. And I'm ready for a super charger down the road. All I have to do it slap it on the car. T/B, Mass Air, injectors... it's all ready to go.
Supercharger with flat top pistons???
I know Accel makes 36lbers, but I like the Ford Racing ones myself...(bias)...
So in that case, get 42lber's with a tune:)
Fuel Injector Selection:
Injector HP Ratings: divide flow rating by .5 and multiply the result by the number of injectors. The following examples use a 100% duty cycle. These ratings are for N/A engines and at the flywheel.
Example:
19 lb injectors/.5 = 38 - 38 x 8 = 304 HP
24 lb injectors/.5 = 48 - 48 x 8 = 384 HP
30 lb injectors/.5 = 60 - 60 x 8 = 480 HP
36 lb injectors/.5 = 72 - 72 x 8 = 576 HP
42 lb injectors/.5 = 84 - 84 x 8 = 672 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP for 19lb injectors
385 HP x .85 = 326 HP for 24lb injectors
480 HP x .85 = 408 HP for 30lb injectors
576 HP x .85 = 490 HP for 36lb injectors
672 HP x .85 = 571 HP for 42lb injectors
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
Courtesy of jrichker...
Several times I've been contacted with a request of why I feel 19's will not
feed all that much power.
The most important thing to keep in mind I tune at stock pressure so that
is my point of reference.
Peeps are so quick to say ... "19's will feed 300 horses" :nice:
Look at that info David provided :)
304 flywheel hp
258 with the 85% duty cycle
258 x .85 for a 15% drive line loss = 219 rwhp
See why Ford put 24's on the Cobras :D
Grady
