what kind of intake? injectors?
95conv5.0
184
im going to be running a 306, with eagle crank, eagle rods, and ross pistons, the copression ratio will be around 10.5 to 1 with the afr 165s i will be running, the 165s will be ported, jsut about forgot ill be running a crane 2031 cam with 1.7s, what type of intake would be the best with this setup? i figure ill need 24lb injector or should i go bigger where i will have room to grow?
24#s are fine, you don't want to go too big. Room to grow into what? A forced induction setup? If so, you will need to drop compression. Intake is up to you, matter of preference really. Trick Flow, Edelbrock, GT40. Do some research and find out which intake suits your powerband the best.
GO with an Edelbrock Performer. It will suit your 2031 power band perfectly! When i had my Performer my low end power was awesome and through the rpm band. But now with my RPM i dont think it is a good match for my cam as the RPM wants to make power up around 6,000 and the cam wants to make power just past 5,000rpm.
sociopath5.0 said:
I'm not saying youre wrong, but so far I ahve only seen them offered for 87-93 models, and he has a 95. I thought of that intake too, it looks fuggin schweet!!! I wish they offered it in a polished finish.
It is good to remember our cars were only made for a couple of years.
No manufacture is gonna go to the trouble and expense to tool up for a different intake for a car that just had a two year run.
Later
Grady
Im pretty sure with the BBK intake u can just use an elbow adaptor like all the intakes.
