What kind of power with my setup??? Supercharged
Well I have been collecting all of these parts so that I can make a good combo and do it all at once. What do guys think my hp, tq, and 1/4 mile numbers will be and is this going to be a safe fullproof setup???
Stock block, heads and cam
Vortech s/c trim with anderson power pipe
Adj fuel press reg
30# injetors
73mm c/l mass air
255gph fuel pump
Typhoon intake
70mm throttle body
msd 6btm
offroad x pipe
flowmasters
aluminum radiator, dual elcectric fans, hv water pump
suspension in sig....
crappy driver....
everything else stock...
Thanks
Sounds similar to my setup, only I have ported stock heads, and don't have a BTM (won't need one with my tweecer ;) just yet) I'm only making 6psi, but my intake is restricted down to a 2" diameter (at most) because of the discharge tube I am using (old SD tube, lol) I'm supposed to be getting one from a friend, still waiting :(
Anyways, with my timing still at 10* I only made 319hp/337tq I was a bit lean with my a/f being around 14:1 which is bad...i was able to bring it down to around 12.5:1 still high, but ran out of dyno runs, just by changing my fp up to 51psi with no vacuum...
Anyways, thisis not tech, please post stuff like this in the talk forum.
