what mods next?
  • Thread starter Thread starter Tranceformer
  • Start date Start date Oct 19, 2004
T
Tranceformer
20
  • Oct 19, 2004
I have about $1500 to blow on my car, just wondering whats the next best mod(s) to do. I already have a CAI, mass air meter, 65mm TB, shorty headers, O/R x-pipe, flowmasters, pro 5.0 sts.
The first thing I'm gona do is rip out the stock 2.73's and put in 3.55's or 3.73's. After that I'm not sure what to I could do. ANY IDEAS???
GRGT1994
1,034
  • Oct 19, 2004
If I were you, I'd have gears on high priority, if not the very next thing you do. Read around a bit, and most say that should be your first upgrade.
Very soon should be weld-in subframe connectors too.
That will leave plenty of cash for other stuff.
9
90pony302
65
southern illinois
Oct 19, 2004
  • Oct 19, 2004
go for gears, some type of cold air, intake, and some type of bracing, maybe ud pulleys too
PhLoBuS
473
Beverly, MA
Oct 19, 2004
  • Oct 19, 2004
G E A R S 3.73's!
M
Matts89LX5.0
1,314
Long Island, NY
Oct 19, 2004
  • Oct 19, 2004
3.73s, Maximum Motorsport full length subframe connectors, UPR Adj Lower Control Arms, Battle Boxes, 65 mm throttle body, and then upgrade your fuel system.
Matt
BossShinoda9701
52
Colorado
Oct 19, 2004
  • Oct 19, 2004
Good decision to go with the gears....it makes a BIG difference...I had 2.73s then went to 3.73s WOW Don't forget your plastic speedo gear...mine is still 6mph off so I am racking up more miles than I am really going.
Depending on what your future plans are...s/c, nos, turbo, or just n/a. If power adder, no to u/d pullies They send a smaller water pump pulley in the kit and you want MORE cooling when you are running boost.
Also Battery Relocation Box if you are doing P/A. ($100)
Subframes are pretty nice and easy to do. While you are doing gears try Alum driveshaft. Makes you hit revs faster. About $150-200 for that.
Also try some type of ignition. MSD ignition module, coil packs unless you have a 5.0 then distributor, Plug wires (8.5mm or larger)
You can do some suspension work. Lower it (make sure you get new caster/camber plates and have car re-aligned), new rear upper and lower control arms, struts and shocks ( i have Koni Yellows those are nice but EXPENSIVE ), anti front and rear sway bars.
List is endless my friend. HAVE FUN BUILDING
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 19, 2004
  • Oct 19, 2004
$1500 can go a long way with a car as stock as yours.
Thumper heads w/ spring upgrade $700.
TMOSS ported lower intake. $130
3.73 Gears w/install $300-400
TFS/FMS cam
Subframe connectors.
That will pretty much dry up the account, maby not be the best H/C/I combo but it would be a night/day difference.
Black 93 Fox
1,995
Vancouver,Washington
Oct 19, 2004
  • Oct 19, 2004
Gears, Intake, Plugs,wires,coil,dist,undrive pulleys, rear lower control arms, sub frame conectors, headers.
cobra dave
308
  • Oct 19, 2004
all i can say is EBAY. Dont buy used gears or a used cam though heard too many damn horror stories.
1991GreeNLX
129
Houston TX
Oct 20, 2004
#10
  • Oct 20, 2004
  • #10
i would buy with 1500 bucks UD pullies and alternator and a suspension kit from Maximum motorsports then get the gears the better the traction the funner the gears will be wont spin as much and youll handl better but then again your money
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 20, 2004
#11
  • Oct 20, 2004
  • #11
You've got $1,500.00 to spend......Here's what I'd do. Go for the gear swap, save a little more and buy myself one of those used KB 1500’s on Ebay. You'll get more out of that than any of the little bolt on items. Not only that, but afterward if you decide to start doing the usual bolt-ons, the benefits will be greatly increased with the forced induction. Most go the bolt on route right off the bat because funds are usually limited and most can only afford to go a couple of little things at a time. Since you’ve got a big chunk right off the bat, why not go for the gusto?
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
I
Engine What Camshaft?
  • Iceman1998
  • Oct 5, 2024
Fox 5.0 Mustang Tech Oct 6, 2024
Z
Engine New head for ‘88 mass air converted foxbody
  • zahirayunus
  • Dec 13, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
zahirayunus
Z
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
