What Should I Do Next?
Hyland33
10
Leicester MA
So i bought my mustang a few months ago and i finally have around $700 to spend on parts for it...I need some opinions on what i should buy...
Already Has
-E303 Cam
-GT-40 Aluminum Heads
-BBK Cold Air Intake
-MAC Shorty Headers
-2.5" Flowmaster Exhaust
-Polished Typhoon Intake Manifold
-70mm Throttle Body
-24lb Injectors
-Solid Motor Mounts
-373's
-B&M Hammer Shifter
-Roller Rockers
-MSD Coil
-Torque Converter with 400rpm more stall
What do you think i should get?
Post some pics so we can get an idea what the car looks like.
It must run good already!! So how about something cosmetic??
Like a nice set of 17X9 wheels??
Need to know what you want the car to do...
Subframes are a must (no matter what).
Then you could go with lowering springs/shocks&struts for a better handling steet car, or you could go with a drag suspension.
Motor seems pretty stout right now. Could get a nitrous kit for it for an extra kick in the pants...
I'll assume you don't want to change any of the parts you have....but you could port and polish the heads and add some 1.7 roller rockers.
Then there are always brake upgrades (bigger system up front, rear disc conversion, etc.)
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
3G installation link:
See the 3G Alternator Install - Roland69 in the "Useful Technical Thread Index at the top of the 5.0 Tech forum. Everything you need to know is in there.
