I just bought a 91 LX. It has (engine):
347 stroker
TFS Heads 2.02/1.60
Crane 2031 Cam
Cobra Intake
Stock Ignition
MVIII Fan
1.7 RR
24 lb injectors w/ Pro-M MAF
75 mm TB
I don't know what the bottom end consists of as far as pistons, rods and crankshaft.
Should I pull it apart to find out, because I want to put a supercharger on it. I don't know if it's high or low compression or if it's forged.
The engine runs great and it doesn't leak or anything except for a bit of seepage at the valve cover.
The trans is a T5-Z and it has 3.73s.
Is it worth pulling the motor apart? The guy said it probably was around 280-300 WHP. He also said he thinks the Cobra Intake is choking it up.
347 stroker
TFS Heads 2.02/1.60
Crane 2031 Cam
Cobra Intake
Stock Ignition
MVIII Fan
1.7 RR
75 mm TB
on top of a DART block combo. They actually no longer make the A-Trim, it was replaced with the SC-Trim which is also a good blower.
