What size do i need?!!!!
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Sep 24, 2008
1 of 2 Next Last
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 24, 2008
  • Sep 24, 2008
I'm doing a nice healthy 351w with AFR 185 heads and blah blah blah. what size injectors do i need? and what throttle body? peace
john
Vipersix
434
Clarksville, TN
Sep 25, 2008
  • Sep 25, 2008
I'd recommend no less than 30# and a blah blah blah throttle body around 70mm.
68stang351
850
9
39
Savoy TX
Sep 25, 2008
  • Sep 25, 2008
If you want 30's on the cheap you can rob them off a couple of Thunderbird Supercoupes or early non-SVO Turbo 2.3's.
I did see an ad for a set of them though for only like 239$ new!
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Sep 25, 2008
  • Sep 25, 2008
+1 on the 30# injectors. However, I say a 75mm TB and EGR spacer at a minimum. I'd be half tempted to go even bigger, but that would require hogging out the intake opening on most aftermarket intakes, and since you are running 185s, it would probably not be worth going 80mm+. Going a little bigger with the TB certainly won't hurt, but going too small will.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 25, 2008
  • Sep 25, 2008
42lb/75 minimum.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 25, 2008
  • Sep 25, 2008
Grn92LX said:
42lb/75 minimum.
why do you say this? do you know someone running what i am? just courious everyone else seems to think 30's will work! also how do i determine my throttle body size i have now! peace
john
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 25, 2008
  • Sep 25, 2008
You said you're doing a "healthy" 351. I have a healthy 347 with 100% maxed out 30lb injectors so I speak from personal experience. Go with the bigger injector and a 75mm tb at least. I see 96% duty cycle before I hit my shift point.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Sep 25, 2008
  • Sep 25, 2008
What A/F are you getting? Power? RPM? I'm not trying to call you out, that just seems pretty extreme for an N/A 347.
42s seem really big for an N/A 351... If you go by this method:
Injector Flow Rate (lb/hr) =
(HP x BSFC)/(Number of Injectors x Injector duty cycle)
And use these numbers:
HP=400 (guessing he might make this with a "healthy" 351)
BSFC=.5 (about normal for an N/A engine)
8 injectors (duh)
80% duty cycle (ideal)
... You result with a 31.25 lb/hr injector.
Using the same formula and numbers, a 42lb/hr injector would be feeding a 537hp motor!
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 25, 2008
  • Sep 25, 2008
I see 96% duty cycle with my 30s on my 347 using real world experience/tools, not internet calculations.
lol @ 400 crank hp. He said a healthy 351, not a weak 351. A weak 351 would make 400 crank hp.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 25, 2008
#10
  • Sep 25, 2008
  • #10
Ok heres my combo. 351 .40 over AFR 185's trick flow R intake and this cam Voodoo Hyd Cam Kit - Ford 351W 302HO 262/268 - Lunati Power also will have l/t's so going off this will it help determine my injecter size? peace
john
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 25, 2008
#11
  • Sep 25, 2008
  • #11
Dude go with a custom cam. You have potential to make a good combo, don't ruin it with a guessing game junk cam! Go with 42's.
NikwoaC- I tuned the car myself with a PMS and a wb 02 meter. The a/f starts around low 13's and works its way into the uppers 12s up top. It goes just under 7,000 rpm. No clue on power, dynos are for tuning and I do my own tuning on the street. I would throw 42s on my own car but I don't drive it enough to worry about the high duty cycle for now.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 25, 2008
#12
  • Sep 25, 2008
  • #12
who would i contact to get a custom cam ground? i talked to a speed shop here and he also said all the 351's he's done needs 42's. so thats what i'll do. will have to chip it but big deal! peace
john
joel5.0
429
Puerto Rico
Sep 25, 2008
#13
  • Sep 25, 2008
  • #13
john
Do suggest Camshaft Innovations for the best custom cam for your setup. Great service, products, and most important, results.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 25, 2008
#14
  • Sep 25, 2008
  • #14
Sometimes I wonder how much commission some of these guys are getting for promoting one guy as the "best."
There are several options out there that will give you everything you are looking for:
Ed Curtis, Buddy Rawls, Jay Allen, etc.
joel5.0
429
Puerto Rico
Sep 25, 2008
#15
  • Sep 25, 2008
  • #15
Assumptions, assumptions......... yet, the best model of a pharisaical statement....
347HO
462
Seattle
Sep 25, 2008
#16
  • Sep 25, 2008
  • #16
C'mon now David, you know I don't make a penny whenever I suggest Camshaft Innovations.
If I had suggested Ed Curtis, would you still have made your post?
I do however suggest Camshaft Innovations (Jay Allen).
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 26, 2008
#17
  • Sep 26, 2008
  • #17
just courious? what does your 347 make at the wheels? whats your combo N/A power adder. peace
john
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Sep 26, 2008
#18
  • Sep 26, 2008
  • #18
Sounds like your motor is a screamer! Like I said before, I wasn't trying to call you out on anything, it just seemed to me that 42s are a little on the big side for a 351. They would allow for some growing room, though, so with a good tune it probably wouldn't be a big deal.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 26, 2008
#19
  • Sep 26, 2008
  • #19
I know you don't Dana. You put the recommendations when they are needed, not every time you hit the reply button, nor do you say that CI is the "best" without having several experiences.
To answer your question honestly, probably not in THIS thread. There are factors I take into account.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 26, 2008
#20
  • Sep 26, 2008
  • #20
I would take a 347 over a 351 anyday, unless you are stroking the 351.
1 of 2 Next Last
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
