What size injectors?
JBeezy53
559
Sacramento, Ca
Just looking for your guys opinions on what injectors to get. The engine will have GT40Ps, Edelbrock performer intake, TFS Stage 1 cam, 65mm t/b, under drive pulleys, accel 300+ ignition, Paxton SN92 at about 5-6psi and a bunch of other little things. I will be going with a pro-m maf.
Thanks, Johnnie.
Are you planning on running it without the FMU? If so, you could probably get by with 30lb injectors. If you plan on running more boost in the future you might be better off to just buy some 42'S
