What size mass air meter for my combo? And I think I fried my 6al!
SilverBullit
221
Tulsa, OK
Well I've got two questions for ya. The first is what size mass air meter do you think i should run with my combo(in sig)? I've already got a 73mm C&L calibrated for 30#ers. And I've also got a friend who is selling a 80mm C&L calibrated for 24#ers. I also already have 30# and 24# injectors. So which one should I use?
My second question is a while back my brother hooked up the battery in my backwards and my switched the terminals that go to the MSD (power and ground) and it won't work. I've got the connector that goes into the top of the coil and when I plug it in the car won't do anything, but if I take that connector out and just run the stock ignition it fires right up. Does anybody know if there is any internal fuses that may have blow? Or can I send it in to MSD and get it fixed? Thanks for all the input!
Casey
24 # injectors and a 80 MM MAF would be my choice unless you plan on forced induction in the future.
Send the MSD box back to them, or at least give their tech support a call for help or an RMA for return.
MSD Ignition
Div. of Autotronic Controls Corp.
1490 Henry Brennan Dr.
El Paso, TX 79936+6805
Main Phone: (915) 857-5200
Fax : (915) 857-3344
e-mail website
[email protected]
www.msdignition.com
www.msdpromag.com
