What the FREAK is wrong with my steering?!
Davin
1,353
Jacksonville, FL
The last couple times I have been on a high speed "flyway" interstate ramp I'll be driving around the curve and all of a sudden my car starts to drift out of the turn as if I cut the wheel that way...I take my foot off the accelerator and give it minor break and it goes away. I should add that this is moderate speed, not "pushing it". Also, when steering at slow speeds, there has been a lot of knocking coming from up front, not sure if this is related though. This is scarry.
good questions...
No it doesn't happen while going straight and this is what's wierd, the steering wheel doesn't not pull like with bump steer, it just starts to float out. The feeling is like when you hydroplane and just can't control the vehicle..
as far as axe (axle?) bushings go...yep.
I'll check the rag joint..could that be causing all the knocking and clicking I've been hearing? I was wondering it there was maybe a tooth in the rack ground down but I don't really know what the insides look like..
