What wheels will fit my car?
Ford wheels ( as well as MoPar) use a 5 lug, 4 1/2 inch bolt circle. Chevy wheels use a 5 lug, 4 3/4 inch bolt circle. While there are slotted, uni-lug wheels out there, most wheel manufacturers these days have dual pattern wheels with a center cap hiding the lug nuts.
yes would have to be 5 on 4.5 specific since the lugs are exposed, 4.5 backspacing is correct, also in the front you cant go wider than 8in w/o rubbing and I hear there are problems associated with 16"x8" rims hitting the upper ball joint... if you go 8" it might be worth considering going to 17" also
