Whats the Big No-No with 4.10's and a SC
derek02gt
255
all the adds ive read say go with 3.73s if your planning a power adder, can somebody please explain this..like whats the reason? and how do 4.10's perform with a Supercharger?
From what I've heard, it's traction.
You won't be able to hook with 4.10s and a SC.
Maybe full suspension and some DR's will help, but if you don't do all that, I'd say get the 3.73's.
Yeah, I would say it is because of traction.
I wouldn't even consider getting 4:10's in my car. Traction sucks as it is. It's a good and a bad problem to have. :p
all i've heard is 3.73 or 4.10's, has any tried 3.90's with their s/c, or is that still a traction and running out of gear issue? or is that even worth it?
4.6MustangSteve said:
Well I'm sure with some sticky tires and a good suspension traction wouldn't be much of a problem.
maybe ill just have to give it a shot once i get a new car :nice:
i guess i should try to find some more info on 3.90's
Kurgan said:
There's a cure for it.
It's called changing your rev limiter to 6500 RPM. A nice set of valve springs helps, too.
Right. My rev limiter is set at 8000 rpm. I have 4.10's with a Novi 2000 and 28 inch slicks. I shift at 7000 rpm and trap at 130 mph in 3rd gear with a 4R70W.
