What's The Rev Limiter Set At From The Factory
VividDreams said:
i dunno about anyone else, but as noted above my rev limiter is somewhere between 6000 and 6200...however, when im doing a burnout, it goes all the way up to 7K!!! anyone know why it allows this?
I've never hit my rev limiter and I've dipped into the redness a couple times, I dunno whats up
The question is....why in gods name are you doing 7000rpm burn outs? Try doing them in second gear instead.
Tachs are often calibrated to read high so the indication is "red" before the engine speed is actually there. My 94 Probe GT has seen the tach needle kiss 8000RPM even though the factory fuel cut is set for 7500. I see no reason to suspect that the MGT tach is much different.
In my Xcal tune I lowered the rev limiter to 6000. 5500 is the best shift point and if I ever get the balls to shift without lifting, I want to know the engine will just be hitting the red instead of well into it when the PCM stops the fun.
