Wheel Adapter Problems!!!!
  • Thread starter Thread starter BlwnGazkit
  • Start date Start date Aug 15, 2007
BlwnGazkit
153
Richmond, VA
Aug 15, 2007
  • Aug 15, 2007
Ok, bought some wheel adapters for my new Bullit wheels and they don't quite fit!
They're 5 on 4.5" but I can't get a socket in the hole to tighten more than one up. If I tighten one down then others won't line up correctly to let the socket fit!!!
I'm quite confuzed... If you guys need pics I'll see, but it's dark so no promises.
10secgoal
2,801
San Diego
Aug 15, 2007
  • Aug 15, 2007
You might have a socket that's too thick. I seen that more than once. You have to tighten them equally. If you tighten one before the others, it won't line up. Just put them all the way down by hand without tightening. Then you just kinda wiggle the adapter as you tighten by hand. Once they are all seated, you should be able to tighten them pretty easy.
dodgestang
1,360
Cecil County, MD
Aug 15, 2007
  • Aug 15, 2007
Thin wall socket is your friend
BlwnGazkit
153
Richmond, VA
Aug 15, 2007
  • Aug 15, 2007
Crap! Thin wall would make sense!!! Hmm, any idea where to get one??
BlwnGazkit
153
Richmond, VA
Aug 15, 2007
  • Aug 15, 2007
How do you tell if it's a thin wall socket or not?? I bought a 13/16 socket today from Napa and I really don't see how the wall could be any thinner with out breaking???
To clarify, the socket fits in all the holes individually, even with a nut in there. It's just once any of the nuts have been snugged up, the socket can't fit in the other holes with a nut inplace. It seems that the holes are off center at that point, regardless of how I try it.
dodgestang
1,360
Cecil County, MD
Aug 15, 2007
  • Aug 15, 2007
Well here's another thing to try....
Stick a socket on 2 nuts at the same time.
Finger tight all 5.
hold a socket on 1 while you tighten the one across the hub from it. If you have a simple problem of loosing center, this will keep it in place.
BlwnGazkit
153
Richmond, VA
Aug 16, 2007
  • Aug 16, 2007
Ok, well I'll try that this afternoon when I get home. If it's a 'No-Go' then I'll post pics of my exact problem.
I did try putting three on at a time. Hand tightened one then got the next one in the star pattern. After that I couldn't fit the socket anymore. I swear I'd think I was doing something wrong!!!
I think I might grind the socket walls thinner and see what happens.
R
ron67fb
1,117
SF Bay area, CA
Aug 16, 2007
  • Aug 16, 2007
How are you sure that you got the right pattern? Is it stamped anywhere on the adapter? Mine says "5450" on it, which means 5 x 4.50. Did you try bolting the adapter to another adapter? If it fits there but not your car then you might have the wrong pattern.
BlwnGazkit
153
Richmond, VA
Aug 16, 2007
  • Aug 16, 2007
True, haven't check the pattern on the one that doesn't fit yet... I did measure the others and they come out to 4.467" center to center.
I guess my studs could also be bent slightly but I doubt it.
BlwnGazkit
153
Richmond, VA
Aug 16, 2007
#10
  • Aug 16, 2007
  • #10
Well guys, I'll be honest I didn't expect this answer....
I called the supplier and after about 15 minutes on the phone the guy asked what size socket I was using. When I told him a 13/16" thin wall he told I was using the wrong socket. Said I should be using a 3/4"... Of course, 3/4" won't fit on the damn nuts!!! Turns out they sent the wrong lug nuts and are now giving me a credit for the nuts and I'll just buy them locally.
HOPEFULLY this will solve the issue.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 16, 2007
#11
  • Aug 16, 2007
  • #11
It will...get some new open ended lugs and you're golden
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
