i read somewhere on here that for the wheels, once u get past 17in, the mm size is only used for how much u want ur wheels to stick out of the fender. is this true, or do i need to find a wheels that 45mm no matter how big it is?
brodude2002 said:i read somewhere on here that for the wheels, once u get past 17in, the mm size is only used for how much u want ur wheels to stick out of the fender. is this true, or do i need to find a wheels that 45mm no matter how big it is?
Jimp said:IIRC, 45mm is the wheel offset. So you'd need to make sure that whatever wheel you buy has that offset or close to it or you may have problems. 20" wheels will fit no problem.![]()
MakotoS13 said:actually offset is based on how much the middle of the rim (width) is (off)set from the true center (where it bolts to the hub). offset does not change at ALL with larger diameter rimss. you want lower offsets to fit wider rims and keep them under the fender. 45mm offset on a 8 inch rim is not the same as a 9 inch rim.
BTW people that put 20's on mustangs oughta be shot in the street.
drtc said:i guess when i get my 20s, ill be the first one u all shoot. lol![]()
