when i unplugg the MAF it dies...
Are you unpluging it while the car is turned on?
The mass air flow sensor converts the amount of air drawn into the engine into a voltage single. The ecm needs to know intake air volume to calculate engine load - which is necessary to determine how much fuel to inject. This will obviously cause problems if you disconnect it. Are you replacing a your current MAF?
