When is torque box reinforcement needed?
  • Thread starter Thread starter MYSTICSVT
  • Start date Start date Aug 3, 2005
M
MYSTICSVT
349
Meridian, Idaho
Aug 3, 2005
  • Aug 3, 2005
When should torque box reinforcement be needed? Is it really needed for a car that is mostly street driven, with occasional drag strip(on street radials) and autocross, use?
I'm getting ready to weld in my subframe connectors, and figured I'd do some reinforcing of the torque boxes while I'm there. If its needed. Mods are in sig.
D
Daggar
3,902
  • Aug 3, 2005
Anytime you own a Mustang. hehe
If you done anything to add power then they're even more important. Lets not forget that the newest Fox is 12 years old.
txstang84
1,639
42
69
Tuscola, tx
Aug 3, 2005
  • Aug 3, 2005
anyone running any kind of performance gear and who likes to thrash the go pedal more often than most would probably benefit from it-whenever you're getting the sub's put in, have them at least run a full bead over the lap joints on your torq boxes, and your upper mount boxes (they're only spot welded every couple inches from the factory)
CE makes a set of torq box reinforcement plates available from either summit or jegs for $30-$35...might be worth investing in a set
squeeeg
1,905
Michigan
Aug 3, 2005
  • Aug 3, 2005
He laughs but it is true. The 5.0 had enough power to tear them up.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Aug 3, 2005
  • Aug 3, 2005
txstang84 said:
..... whenever you're getting the sub's put in, have them at least run a full bead over the lap joints on your torq boxes, and your upper mount boxes (they're only spot welded every couple inches from the factory) ....
POM: Piece Of Mind
Torque box reinforcement with cage?
  • DeathProof88
  • Jan 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
DeathProof88
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
