I have an alum. radiator that measures 2 1/8" wide at the bottom. My stock rubber mounts, well, one is missing and the other is dry rott. Does anyone know if the stock lower mounts will work on an after market alum. radiator and if so, where can I get new ones? If they don't or won't work what did some of you guys do to fix this? I have searched and have failed. The fail boat has left port and probably heading to Somalia.
Thanks,
Ben SEMPER FI
p.s. I heard that f-150 lower mounts might work. Must be a bit wider.
Thanks,
Ben SEMPER FI
