Where to shift at ?
  • Thread starter Thread starter 92Stang302
  • Start date Start date Mar 8, 2004
92Stang302
93
FL
Mar 8, 2004
  • Mar 8, 2004
At the moment im curious where i should be shifting at so far here is a list of the general mods:
B303 Cam
65mm throttle body
65mm egr plate
GT40 heads (less then 1500miles, w/ 3 angle valve job, new burrilium valve guides and seals)
Crane 1.7 RR
Trick Flow valve springs
MSD Blaster Coil
190 Fuel pump
BBK long tube headers
BBK Off-road h-pipe
Flowmaster 2 chamber muffs
Richmond 3.55:1 gears
A/C Delete
P
PonyBoy90
555
Toronto
Mar 8, 2004
  • Mar 8, 2004
Shift by the sounds of the engine. I shift somewhere between 2000-2500 RPM intervals. Some guys push it to 3000RPM's.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 8, 2004
  • Mar 8, 2004
Ummm PonyBoy, I'm guessing that he means at WOT, but I guess that would do too.
92Stang302, I would take a shot in the dark and say between 5600-5800RPM, but it's really going to depend on where your power falls off. Generally speaking, you're optimal shift point should be about 200RPM past your peek. Your combo looks good, but it’s probably a good time to upgrade from your stock MAF and Intake manifold. They seem to be the bottleneck in your list right now.
92Stang302
93
FL
Mar 8, 2004
  • Mar 8, 2004
yeah those are two upgrades intake and MAF that are on the Waiting list
yeah i meant when im drag racing where to shift?
J
jjd975
4,236
louisville,kentucky
Mar 8, 2004
  • Mar 8, 2004
Try 5400 and just work your way up. Keep track of your time slips by writing notes on them.
408cid
Fort Wayne Indiana
Mar 8, 2004
  • Mar 8, 2004
spend a few bucks and get a couple of dyno pulls then you can see where your horsepower starts to drop off. If I had to guess I would say 5800 rpm
92Stang302
93
FL
Mar 9, 2004
  • Mar 9, 2004
so i should set my shift light for 5400rpm on my tach? or start from 5200 and work my way from there ?
NKau
1,346
Jefferson, WI
Mar 9, 2004
  • Mar 9, 2004
That's what I would say. That stock intake starts to really choke the engine at 5,000 rpm. 5,200-5,400 will probably be about right IMO. You can shift a little higher in first and second, but I would guess you should be shifting out of third by about 5,200 rpm.
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
LESS THAN 9.5 MPG CITY DRIVING!!!
  • PonyGTrider
  • Dec 15, 2022
  • 3 4 5
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2023
PonyGTrider
Engine A few issues with my new 88 Foxbody that i couldnt find definitive answers to....
  • AydenTv
  • Mar 6, 2022
2K
Fox 5.0 Mustang Tech May 23, 2022
7991LXnSHO
