which computer is best for my combo?
Merrickd
98
Madison/Janesville,WI
Hey guys! I have a 91 LX stick car that I burned up the original A9L computer. I am frustrated because its seems very hard to get one of these in nice condition to replace mine. After going to all the local parts stores I found these to be on back order. So my questions are:
Should I keep looking for an A9L?
If so, what numbers off the label do I need to match up to make sure the replacement works?
Since I have 24 lbs. injectors and matching MAF should I get a 93 Cobra computer? If so will it work fine after I plug it in?
Any help would be appreciated, because I am sick of having a big calypso green paperweight!
To run a 93 cobra computer with 24lb injectors you will need to replace you MAF/MAS with one from a 93 Cobra.
Worth looking into, but it may be too pricey to be worth it.
The A9L is the best computer you can use.
An A9P is an alternative.
Performance will be very similar for all 3 of the computers I have mentioned.
jason
