who can give me some specs.....?
maxine-70
Mar 27, 2003
273
louisville, ky
i would like to know the specs for the following, if anyone can help me....
the compresion ratio of a stock 1996 351W F150 (it had E7 heads).
the compression ratio of a stock 1996 explorer 5.0 motor (not the P heads).
the CC size of 1996 GT40 (not the P) heads from an explorer.
the CC size of E7 heads.
thanks!
i figure the 351 was 8.5 or so, and im trying to figure out what it would be with my current gt40(non-P) heads that have been milled .030. its such a clean low mile short block i dont want to have to swap pistons to get to the 9.5 or so i'd like to have...i just want to figure out what it would be
You should be able to have the shop that mills them check the final cc of the bowls...that'll get you a step further and at least you'll know what your heads are when you figure out what the short block is.
