Who makes the best 347 for high reving NA use?
I am thinking about dropping in a 347 shortblock into my 91 stang for high reving NA use (and maybe a little bit of nitrous :nice: )
I am looking at the DSS 347 block and I am wondering what other 347 shortblocks are out there that would work with my twisted wedge heads? I am kind of new to the mustang world (converted from the WRX and turbo Subarus) So who makes good shortblocks in general?
U may want to consider the 331 for "hi rev" use. It has better wrist pin placement for less stress on the cylinder walls. There is plenty of info u can look for that will back that up, 331s rev better, longer, and faster then the 347. Also, u need to let the company know( whomever) that your using TWS TW heads, because not all pistons will work with that design. Stock lifters are good as long as you upgrade your valve springs to handle the lift, may want to get some new pushrods. Also...i recommend a custom AFM " Hi Rev" camshaft...beautiful little things they really are..they come with Hi Rev valve springs...
But if you really want a 347, i would use the stock bore, 4.000, and have yourself a 342. The extra beef around the cylinder walls will give you added strength in the long run... :nice: U could get away with using a new stock block, they can handle 7200 rpms, just keep the HP realistic..500+ is a no no...
