Yeah, I think I'll do that for now. But I still need to use 10g wire from the relay boards to the fan, right?If you use a toggle to just activate the relay, you can use something light, like 1amp. The toggle is just supplying enough current to latch the relay. All the heavy current is passing through the relay.
They only made them for about 6 years but the later ones are great!What years contours should I look for for the fans or are they all the same?
Just happened to stumble upon this when "fixing" one of my computers.
1. I would not recommend using relays for this fan. Use a soft start controller, DCC FK-45 or Derale (which is a DCC design under license).
2. You won't need the PiMPxs ECU to trigger the fan if you use a soft start controller.
3. You can mount the controller right on the fan shroud. I actually attached it to a scrap piece of aluminum extrusion to aid in cooling (probably not necessary).
I went through 2 fan controllers, 1 of which was a Derale. They can't handle the amp draw. Going to 10g wire and using a toggle to activate the relay(Leash Electronics single 70a relay board) is working great for me. I also have a 100a breaker between the fan and the relay board. I just got my PiMPxs today(It literally came in the mail today)and I have been communicating with Stinger about my fan setup and they said just run the fan wiring that comes in the harness to the wiring I have setup. I ordered the engine harness for the PiMPxs also. So I'm going to go that route.Just happened to stumble upon this when "fixing" one of my computers.
Congrats on the PiMPxs arriving, you're gonna love it! I'm following your build thread so looking forward to seeing your progress with it, especially since you're using their engine harness too.I went through 2 fan controllers, 1 of which was a Derale. They can't handle the amp draw. Going to 10g wire and using a toggle to activate the relay(Leash Electronics single 70a relay board) is working great for me. I also have a 100a breaker between the fan and the relay board. I just got my PiMPxs today(It literally came in the mail today)and I have been communicating with Stinger about my fan setup and they said just run the fan wiring that comes in the harness to the wiring I have setup. I ordered the engine harness for the PiMPxs also. So I'm going to go that route.
Haha yes I did see it, but only took note of the fan itself (and the crazy amount of air it pulls!) and not the wiring config you used. Do you run the relays directly to the starter solenoid/battery or have a fuse in between? Do you think these (nice and cheap) relays wired in parallel would do the trick since they're rated at 80 amps each?Well you saw my setup in person. The ECU triggers 2 relays 60amp wired in parallel, these are wired to a single #8 feed for the fan. I notice no issues with the setup, no hot wires or burned up relays. Been like this for years.
Yes I already have a 3g 130 amp alternator installed. Thanks for the controller schematic offer but I don't trust my electrical abilities enough to want to build one from scratchJust in case you haven't already upgraded the alternator to a 3G or other high current alternator, plan on doing so.
I have had an FK-35 for over 20 years.not sure the FK45 has enough amperage for that fan....
Relays are a "hard" start, PWM controllers are a "soft start". My PWM has led indicator mounted in dash.Thanks for the response @Blown88GT . Since I already have the ECU set up to trigger my existing fans, I'm not really looking to add an additional fan controller. Plus I like having the flexibility via the ECU to trigger them for whatever conditions I want to define as well as visually being able to see when they are on/off via the tuning software dashboard.
Is there a reason to avoid using a relay for the Mark VIII fan in particular?
I'm just trying to avoid buying a controller if I can accomplish the same result via a relay/fuse combination, provided it is safe to run it that way.
