why cant i burnout?!
  • Thread starter Thread starter jstang209
  • Start date Start date Mar 13, 2006
First Prev 2 of 2
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Mar 13, 2006
#21
  • Mar 13, 2006
  • #21
lol yes..
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Mar 13, 2006
#22
  • Mar 13, 2006
  • #22
i got the rearend from a 5.0 obviously which has quad shocks, i removed the rearend with the quads still attached to the it.. There is not place to bolt them up to on a 2.3 car so i took them off.. I really cant explain it more clearer than that hehe
willys1
1,004
New Jersey
Mar 13, 2006
#23
  • Mar 13, 2006
  • #23
jstang209 said:
lol yes..
DUDE,,if you took em off then there "is" mounting points for it rite?
willys1
1,004
New Jersey
Mar 13, 2006
#24
  • Mar 13, 2006
  • #24
jstang209 said:
i got the rearend from a 5.0 obviously which has quad shocks, i removed the rear with the quads still attached to the rear.. There is not place to bolt them up to on a 2.3car so i took them off.. I really cant explain it more clearer than that hehe
oh ok...Buy some upper and lower control arms then,it will cure the problem!!
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Mar 13, 2006
#25
  • Mar 13, 2006
  • #25
are u blonde??
j/k
CobraWannabe
321
Lancaster, PA
Mar 13, 2006
#26
  • Mar 13, 2006
  • #26
Yes. There is mounting points ON THE REAR END. There is NO mounting points for them on the 2.3 CHASSIS. They have to connect from the rear end to the car. There is no mounting points on the car. Only on the rear, which is why he removed them from the rear end. Because they would have just hung off the rear end because there was no where to mount them to the car.
But wait. My 88 4 cyl conversion has mounting points for quads. shrugs
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 14, 2006
#27
  • Mar 14, 2006
  • #27
make some mounting points on the 2.3 chasis or lower C/A's
C
conv91lx
144
Bloomington, IL. USA
Mar 14, 2006
#28
  • Mar 14, 2006
  • #28
I would start by just replacing the 2 shocks you do have. They are probably shot and not dampening the rearend properly. This would be the least expensive "fix" to start with. Go to better control arms next.
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Mar 14, 2006
#29
  • Mar 14, 2006
  • #29
where is a good place to get some good but cheap lower/upper control arm kits that come with bushings and hardware?
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Mar 14, 2006
#30
  • Mar 14, 2006
  • #30
i would think ebay would have some cheap ones but all i have to say is u get what u pay for
http://cgi.ebay.com/ebaymotors/Must...ewItemQQcategoryZ33583QQitemZ8045201598QQrdZ1
P
powermaxx
168
melfort, sk
Mar 15, 2006
#31
  • Mar 15, 2006
  • #31
maybe try some local wrecking yards
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Mar 15, 2006
#32
  • Mar 15, 2006
  • #32
jStang... not making fun- but if you didn't have those "Pimp my Stang" wheels on it the spinning would be much better.
+1 for LCA's
(they won't stop you from spinning )
J
jstang209
20+ Year Stangneter
Jun 3, 2004
640
Stockton 209
Mar 15, 2006
#33
  • Mar 15, 2006
  • #33
people run bigger slicks than my tires, so i guess its an overall problem. Also there only 2 inches bigger than stock tire size, so thats really not a big difference. It just barley started to happen recently 2, ive had the wheels for a while now. Cant really think of anything else i might of done to cause it.
fidstang
307
South Lansing
Mar 15, 2006
#34
  • Mar 15, 2006
  • #34
I had the same problem with stock pony wheels and 245 50R dunlap 8000's. I replaced the lower control arms with megabyte jr's and now I can burn through 1st, 2nd and part way through third without any wheel hop. First thing you should do is replace the shocks with blistin or any high end shock. Then get some good lower control arms.
willys1
1,004
New Jersey
Mar 15, 2006
#35
  • Mar 15, 2006
  • #35
I ran a slick that was 2 inches taller then my DR's,it slowed me down 2-3 tenths in the 1/4.
First Prev 2 of 2
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
