Why does it die?
  • Thread starter Thread starter Jimmys66
  • Start date Start date May 1, 2007
J
Jimmys66
419
Paw Paw MI
May 1, 2007
  • May 1, 2007
When I make a hard stop the motor chokes and after a couple of good pedal pumps, the motor cleans out.
To me it seems like it is flooding out. My first thought was the float bowls were set to high. After checking them, they are set correctly.
Any suggestions?
Biggs (holley)650dp on a 302.
iskwezm
4,159
20
79
Rowland Heights,California
May 1, 2007
  • May 1, 2007
float set too low????idle too low?
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
May 1, 2007
  • May 1, 2007
I had this same problem once with my 78 Mustang II.
I was able to fix it by adjusting the idle mixture.
krash kendall
1,258
Aldergrove, B.C. Canada
May 1, 2007
  • May 1, 2007
If you brake really quick and hard, the engine may die due to the torque convertor not unlocking fast enough.
J
Jimmys66
419
Paw Paw MI
May 1, 2007
  • May 1, 2007
It's a stick so I can eliminate the converter. When I'm braken' I've got the clutch in so it's not like I'm draging the motor down.
It idles at roughly 950rpms.
I could try bumping up the floats. When I checked I looked to see if it was too high and flowing over. I wasn't getting any fuel out of the plug. I'l bump it up tom. until I get a little out of the plug and see how it does.
2nd Mustang
2,488
Southern California
May 1, 2007
  • May 1, 2007
If it has power brakes, try plugging the line from the intake to the booster and try a hard stop, but make sure you have a lot of space to stop.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
May 1, 2007
  • May 1, 2007
Without a baffled chamber, it will eather starve or flood on hard brake or corners. I Set the floats on level ground idling,With the manual trans, 650 rpm
with the sight plug off and adjust float so it has fuel at the lower lip of the hole.
You should see fuel with just a nudge on the frontend.
J
Jimmys66
419
Paw Paw MI
May 5, 2007
  • May 5, 2007
Got it. It was the seconday float.
I was making a rookie error. The float level onlys changes in the secondary when it's opend enough for the rear 2 barrels to dispence fuel.
Thanks again.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
F
Best plugs for carb'd roller
  • forango
  • Nov 21, 2025
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
HotFox
  • brandyn200
  • Jun 20, 2026
AeroCoupe
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
