Wheels-Tires Widening Sn95 Wheels - How Wide Can You Go
Mustang5L5
Mod Dude
Feb 18, 2001
43,253
17,937
224
Massachusetts
Rear wheels, on Sn95 axles. Take your standard 5.72" BS 17x8 wheels, and how much can you add to the inside before it becomes an issue?
WHat BS/offset are you guys with 9" and 10" wide wheels on Sn95 axles running?
With my 17x8 Cobras, it seems like I have a decent amount of room. But my main concern is articulation.
Tailpipes are also a concern. I don't want to remove them
I could possibly add a small spacer and come out a tad as well
Sent from my big ass iPhone 6 using Tapatalk
I looked into this years ago but stopped my research when the wheel widening companies only did widening by the inch, I felt like an entire inch was too much inboard and I didn't want to use a spacer.
I forgot about that little detail. Really means I'm going to be limited to adding 1".
That gets me to 6.72" BS which is about 1/4" further in that some of the combo's I've seen running 6.5" BS wheels. I really don't want to run a spacer here either, and would prefer to keep my tailpipes.
I might have to give this up as well. Guess there's a reason why you don't see many people widening SN95 wheels on the fox body
So bumping this again.
Got my new wheel/tire setup on the car and taking a look at this again.
SN95 17x8s, with 255/45/17s mounted.
Some pics of current fit.
I'd go 1" wider on the inside with the goal of getting a 275 on there. Those quads are not flipped. I feel like getting 20mm of tire in the inside is doable.
Of course, cost. $200/wheel plus a new pair of tires.
Reactions: General karthief
