Window problem 2008
2008 windows will not open or close. Windows ‘dip’ and ‘seal’ with 1/2 inch movement when doors are opened and closed, but will not go down with door operated switches. Both sides affected and recent problem. My conclusion is window motor is getting power and motor works due to dip and seal action, but why would all door switches quit at once? Computer?
Update: solution was bad 5 A fuse @ #6 location ‘accessory delay feeds’ passenger kickplate location. Labeling corn fused me, why couldn’t it be labeled ‘door window switches’ or something average joe would recognize. My thanks to this website for saving me $120.00 to replace a fuse!
FYI update. While reading another post and replies someone suggested checking 5A fuse in passenger kickplate fuse box.
While number positions were different I found a fuse blown at location #6, a 5A fuse, listed as ‘accessory delay feeds’, replaced same and now door windows operate properly. Yea! Mickey-dees, Super Sonic, Dairy King are back on the menu.
Still can’t figure why trunk blasters don’t work, but that’s another day.
I also taped a plastic baggie over fuse box as blown fuse looked as if it had seen water.
