YOU'VE BEEN A BIG HELP. NOW HOW BOUT SOME HELP WITH THIS 1
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
on a 1993 eddie baur explorer with the 4.0 in it. when you put water in it or start it it pours out the rear of the engine right over the bell housing? i cant see where it is leaking from so any ideas? peace
john
From what I hear, the non-sohc 4.0L's are notorious for intake manifold coolant leaks and for freeze plugs rusting out. Need to take a closer look and pinpoint the highest point that is wet. Also check the valve that controls the heater, right around the heater box (above it) they are often a source of a leak.
