Zeitronix ZT-2 WB data logging Need Input
toyman
1,944
54
79
Vernon BC
I am unable to read the rpm's due to rapid fluctuations. For those who have the ZT-2 I need to know where you have the black wire grounded and where you have attached the green wire (tach input).
Richard
Richard
So as to not leave this thread hanging.
To get the Zeitronix ZT-2 working on 94-95's you must tap into the PIP signal wire at the PCM ( grey/orange stripe at pin 56). Ground can be at the PCM ground or better yet a dedicated wire from the battery(-).
The tach lead from the coil just does not work due to voltage spikes. I am told that the tach output from ignition boxes will work.
Richard
toyman...... Its been over a year since I wired mine in so off hand I dont remember. I will try and get over to the car to check out what I did and pm ya with how mine is wired in.
