Hey guys,
Doing a little research here and 4 cyl fords are not where my experience is.
My next project is going to use a 2.3L NA from a 88 mustang. The car its going into is going to be under 1500lbs and used for street driving and autoX. T5 from 90 mustang and 3.73gears (rear is from a 85 automatic). All stock except will have headers/exhaust and a custom intake (to fit under-hood). The intake will either be stock lower runners with a plenum aimed forwards (simpler), or a custom short runner/large plenum intake (more flow/lighter).
Anyhow, I have zero experience with 4cyl so looking at cams they either seem stock, or bloody huge for a 4cyl. Im guessing mostly dirt track or turbo cams??
What do you guys figure a good sized cams for my needs is? Id guess with headers/intake I would go for a little more duration, but I don't want to bleed off any compression. I don't think torque is a concern with 3:73s and low weight. I can handle a pretty rough idle, but only if its needed to gain more power. Any ideas as to approx hp? Good redline for a box stock 2.3L?
At some point I will want to add a few lbs of boost, but not until the car is built/setup.
There are better/lighter engines out there but I have had a fleet of these things as beaters so I know they are tough, and it looks like a reasonable aftermarket.
Thanks for any help guys.
CoryM
This is pretty close to what the car will look like btw:
http://www3.telus.net/public/corym/blk7.jpg
CoryM
I figured anything from 88 would be done in rwhp numbers. Ok, well in that case I'd still only have to add about 12 bhp (SAE NET) to have the same power/weight of a stock 5.0L (according to whatever website I looked that up at).
