Quad Shock Rubbing in 17x9 Cobras
magnj
139
Hey Guys I did a 5 lug swap with Ranger Axles and drums using 03 17x9 Cobras and did not expect to have clearance issues but the Quad shock is actually hitting the Wheel not the tire.:notnice: I don't want to go without them long term but is it ok for me to drive about a half hour on the highway back to school and replace them later this week? Also what is the skinniest one I can get my hands on in either the correct or backwards configuration.:shrug:
Thanks guys
focking n00bs :mad:
Be nice :nono: , I was not suggesting driving with the quad shocks rubbing I was wondering if I could take them off for a while until I can replace them.
yogibear357 said:
your axles or your back spacing on the wheels are wrong. I know my wheels are 5.6 back space. Don't remember what the axles are
My Wheels are Wheel Offset: 26mm offset and Wheel Backspacing: 6.12 The rear right seems to be rubbing more, I just rolled my car about 5 feet forward and that was the only one making noise.
Any tips on a skinny quad shock?
Have you tried flipping them around! That might work
:lol: I WAS being nice, last I checked, keeping people from killing themselves is generally considered to be doing them a favor. :shrug: You've got too much backspacing, it needs at least a 1/4" bolt-on adapter-type spacer (maybe more) to make those fit right, from my experience with Foxbody wheels and backspacing, you need to end up with more like 5.8" B.S.
Fix the cause, not the problem! :nice:
He meant take the quads shocks off.
Yes you can drive without the quad shocks. You may notice more wheel hop, but it's perfectly safe.
You could try flipping them around for more clearance.
Yea I'm going to take them off until I can get more information about which new ones might fit cause these are absolutely shot anyway I'm pretty sure they are original.
5.0ina66 Thanks for looking out for me. :) I was under the impress that spacers are not the best idea, is that correct?
Ok, I'll see if I can get away without them for now, according to the SN95 swap pages they say a 17x9 R58 Cobra R rim will fit with the ranger axles and those have 5.9" backspacing if I can find a 1/4" with flipped quad shocks I'll do that.
Thank you! I have seen those mentioned before as a good replacement and will definitely check them out. Unfortunately my car is going to have to sit for a few weeks its crunch time at the end of the semester and I have to try to keep my priorities straight lol
I had the same problem, the stock quads( don't know if you still have them) to me are the best. they have a long skinny shaft and the body is small and flat on the sides, I don't know about the gabriels but the flat sides of the body I think are key if the body is round that could be a problem. the body of the shock just cleared my wheels but the stock quads seen better days. I bought the kyb ones but they hit even when flipped, the guys on here had me cut the dust shield off but still no good for my application. I found out that the later models stangs 94 up to around 2004 I think used the same exact quads they matched up perfect, looked the no different than my 1991's. I put them in and no problems.
I called steve at Tousley ford and got some quads from a 95 or 96 mustang. He gives Mustang guys a 10% discount over cost not list cost. I get just about all my frod stuff from him. The number is 1-800-328-9552 just tell him you are from stangnet. I don't know if this will what you need but I figured I would post it up anyways.
No thats great information, I'll flip the stock ones and see if that fits. I did notice that they seem to be the smallest but was unsure if I could get my hands on any that would be in better shape.
First of all. 03 Cobra wheels have more backing spacing than SN95 Cobra wheels. 17X9 SN wheels are 5.95, (24mm offset) and 17X9 03 Cobra wheels are 6.13. (26mm offset) It isn't a HUGE difference, but every bit helps.
First, this is free....flip them around.
Second, take them off, and get LCA's. They won't eliminate wheel hop, but they help. It helped mine a lot, but I still have it.
Thats what I was getting at, I don't think I need to find all that much space, a flip should do the trick...hopefully because I'm not trying to spend $$$ on LCA's but it is an option.
