i'm confused by your valve covers.
how did you get one for the passenger side that had the hole towards the rear of the car.
did you get two drivers side ones?
i was buying those at the swap meet, then i realized the fill tube would hit on the throttlebody with the sn95 elbow.
Better be careful cleaning your block up, the paint where the oil filter goes cant be good for sealing. Other then that looks like your making good progress!
so today i installed the oil pan, timing cover, cleaned the water pump. installed lifters the last of the new valve springs, pushrods, rockers...
i then moved on to priming the water pump, and then spraying the rest of the block, valve covers coat #2 and lower intake... the paint gun was clogged so i have it soaking in paint thinner... i wasted 2 hours... but got a decent amount accomplished. The new valve springs are beefy as hell.
O a side question, 2 of the valves arent seating all the way... they have some serious carbon build up. Any way of cleaning them up, even after the car is up and running or before hand.
yellow,
I have a novi 2k and was windering if you clocked the blower housing to get that pipe to work, and if so, how would I go about that, and where did you get that pipe.
Secondly... How well do those valve covers fit with the novi and such. I've always wanted those covers, but even the cheap ebay chrome ones I have, have problems with the novi hitting them and almost being too tall for the throttle linkage...
Why didnt you take the C/C plates off before prep and paint?
RC
