Rear gas tank and front tilt hood pics..
dood this build thread is awesome :drool:
i cant believe i posted in it a year ago, so much has changed since then LOL
you have one SICK ride man, and you did it all yourself which must feel awesome :nice:
btw, i still dig the gas/hood mods lol
EDIT: just checked, less than a year, but sure feels that way :shrug:
Thanks I had a time when I didn't do anything maybe for about six months, No money, I bought a house and had new bills,but im getting on my feet again.Thanks again, I will try to post more pictures as I go along.
heres some pictures that I took of my hood, and master cylinder, I will post some better ones tomorrow I got my cam back.Were should I put my msd box? were is at in the picture, up against the engine bay or hidden behind the fenders, let me know.CAR IS A LITTLE DUSTY!!!!
ok guys im going to hide it. Thanks. finished up my brake lines hid them behind my dash and ran my wiring also behind my dash it was a tight fit but got it in now I have to run the wiring that goes outside and put my dash back in...
Wiring and brake lines updates
Ok today I worked on the stang and I ran the brake lines behind the dash ran my wiring behing the dash also put my heater box in.....heres a picture of the wiring coming out of the pasenger side...
Heres a picture of the brake lines going into the passenger side
here are my brake lines coming in from out side..
Heres my wiring thats going behind the dash you can see the brake lines also
Here Im trying to put the box in, I used some speaker wire to help me pull the wires because my hand did not fit to fix them where i wanted them...
And here it is in
:mad:I had to take the box down again forgot to put that damn plastic cover, here it is with the cover..:mad:
heres the wiring a little nicer may need to move some things around..
heres how it looks from the engine compartment
Sorry its so dusty...I will clean it up when im done my wiring..Will post some more pictures when Im done with the driver side...
How many hours have you put into the wiring so far?
I had started my wiring a while back before I cleaned up my bay that took me about 5hrs off an on taking breaks , I had to cut open the big chunk of wires a seperated the passenger and driver side,but hiding the wires behind I just started that recently.when I took my dash out before I painted my engine bay. I started cleaning it up little by little maybe about 3 hrs cleaning it up and putting new heat resistant/ fire retardant tape. It was just the behind the dash wire I really had to modify every thing else is in the same place I had previously ,just hid them specially the wires that go to the head lights. That was just plug in and hid right under the front top part of the radiator support. That took me like half an hour because I wasn't sure how to put back the air bag sensors. And it took me like 1 hr to tape and put new plastic tubing on the passenger side. Hope fully the driver side goes by faster since I had them wired previously now the only diiference is that it will be coming out a different hole..The only mods I will be doing is my MSD box, which I never had one and will be new to me so I might have some trouble putting that in,( I don't know how the wires go)So if I add up my wire time It would be about. 20-25 hours. Almost a whole day!!!!!!I did it in sections so It didn't really felt it.. Time well spent!!!!:nice:If you look at my car domain you can see a picture of my car when it was open when I had just done my wiring...
ok I finished my passenger side and my new brake lines. Just need to buy a coupling to connect two line together.Just need to finish up my dash to put it in the car to wire up my driverside wiring... will post some pictures up later
:D MORE PICS MORE PICS MORE PICS
I will be posting more pictures finished cleaning my dash an my wiring on my dash to clean it up some more. The more I touched the factory tape it keeped falling apart so I had to redo the whole wiring.It came out good. Just wanted to figure out the vacum hose first so basically i only need one coming into my dash for the ac/heater... Right?then the booster I wanted to plug it in straight. The only on left will be for my egr(DO i really need this if im running no smog stuff?) and for my FPR.
any updates? I know it's warm where you are so you probably can still work on your car.......
Well I'm done with my dash I put it in. I have three wires that I don't know where they go I will put some pictures ot them to see if you guys can help me out.I also finished up my brake lines and finishing up my driverside wiring just have to mount the msd box and run some more wires then secure them in place. I received my fuel lines two days ago. just have to wait for some fitting to do my fuel lines. but its coming along slowly but surely. No its not that cold here but have'nt had time to work on the car..Will post some picture of the wires....
